Discussion topic: Main box not connecting to mini box
Message posted on 27 Feb 2024 01:29 PM
The main box is not connecting with the mini box, the blue q has disappeared and not lighting up. The second tv just keeps saying no signal.
Message posted on 28 Feb 2024 08:23 AM
Re: Main box not connecting to mini box
Hi there @Sayema , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Message posted on 01 Mar 2024 08:37 AM
We are still looking to help you @Sayema . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Message posted on 01 Mar 2024 09:06 AM
Hi @Sayema Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, do the same with the Mini box?
Message posted on 01 Mar 2024 11:49 AM
@Sayema are you sure that the second TV is on the correct HDMI input with the mini box turned on and showing the green light try using your TV remote and going through your HDMI inputs by pressing the source button on your TV remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
