Discussion topic: Main box no programme/recording picture or sound
This message was authored by: melw
Re: Main box no programme/recording picture or sound
Hi @melw
Have you tried rebooting your Q box.
Avatar for melw
Thank you for your reply. Reluctant to do the mains off reset because mini box is working OK. Will I have to reset the mini box after and will it automatically reconnect to the main box?
New to sky q, recently moved from sky +.
Wish I hadn't!!
Wish I hadn't!!
Rebooting the main Q box will not affect the connectivity of the mini @melw
Obviously the mini will be offline during the reboot until the main Q box is back on.
Avatar for melw
Thanks again @oldfella  Will try tomorrow.
Avatar for melw
Turned on Sky Q box (using remote control) the following day and working OK.
@oldfella
