Discussion topic: Main Sky Q box keeps freezing
Message posted on 04 Nov 2023 10:42 AM
Sky Q box keeps freezing and i have to power down continually to get it back
Message posted on 04 Nov 2023 10:47 AM
Re: Main Sky Q box keeps freezing
Message posted on 04 Nov 2023 10:51 AM
Just in normal use, we will be watching a channel, then go to change channel and nothing happens. We end up having to power off and on to clear. The issue is happening daily
Message posted on 04 Nov 2023 10:53 AM
Hi @jon66
If the issue continues best to contact Sky for an Engineer to check your equipment
Message posted on 04 Nov 2023 10:55 AM
We have tried that and still have the same issue.
Message posted on 10 Apr 2024 03:43 PM
Did you find out what was coursing the problem they have replaced my dish and 3 main sky Q 2TB boxes, he is going to try a 1TB box to see if that has the problem too now.
Message posted on 14 May 2024 04:07 PM
@jason+alldridge @Did this solve your problem? I'm having to restart 4-5 times a day....and that's the replacement box!
Message posted on 29 May 2024 09:38 PM
I am having same problem. Every day it is happening. Sometimes don't notice until I want to change channel or look at TV guide. Nothing works via remote. Can't turn off even. Have to switch off at mains. Very frustrating as losing some recordings due to "power cut" but its not! If watching a recording blue circle continues and red light on if recording something else.
Message posted on 30 May 2024 10:09 AM
I have the engineer coming out tomorrow. I'll let you all know what he thinks.
Message posted on 31 May 2024 08:18 PM
How did you get on?
Message posted on 31 May 2024 08:43 PM
The engineer was very thorough, checked everything - changed the power unit for a new one and changed the sky connectors on the satellite feed. Told us it might make a difference, but it might not. He said he couldn't understand what the problem was or why it was happening.
It didnt make any difference, the box froze again less than 3 hours later 🤦🏼♀️
Message posted on 04 Jun 2024 01:23 AM
Any luck since?
Message posted on 18 Jun 2024 06:49 PM
Also now having this problem! Anyone get to the bottom of it?
Message posted on 18 Jun 2024 09:59 PM
Also having the same issues. Sky q freezing and cooling fan keeps radomnly coming on. Only way to reboot is to pull the power cord out. Now on the 3rd sky q box. Already had an engineer visit no change. Sky saying the soonest they can get an engineer out is in 3 weeks. Absolute joke.
Message posted on 18 Jun 2024 10:08 PM
No, still the same.
we have plugged the sky box into a smart plug though, so we just tell Alexa to turn the damn thing off and on again. Just makes it a tiny bit less of an **bleep** ache.
