Discussion topic: MR004
This message was authored by: Cheryl314
MR004
Hi I keep getting this code MR004 it's worked all day and for the past two hours I've tried everything to get it back on but just keep getting this code
Re: MR004
Hi @Cheryl314 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot, do the same with any Mini boxes?
This message was authored by: Dallen9798
Re: MR004
@Cheryl314
On the mini box go to Settings > Connection to Sky Q Box > Re-activate
If that doesn't work reboot your Main Q Box, when it comes back on go to Settings > Watch on Sky Q Mini > Re-activate
Should sort it
My views are my own and I will assist where possible.
Sky Q 2TB UHD, 2X Mini Box, Sky BB UF1, Booster 4
I am just a customer, If I've got something wrong feel free to tell me, If I've something right mark it as an answer
This message was authored by: Cheryl109
Re: MR004
I've tried all that about ten times still not working
This message was authored by: ed101
Re: MR004
Having the same issue. Its been 2 weeks, doing a reset every day and it hasnt come back online! What a waste of money and time
This message was authored by: Harona
Re: MR004
Hello,
The above recommendations are good. If none works. Check whether your Sky Viewing Card has not popped out slightly.
Push the card back in and follow the process again.
This message was authored by: ColinTye
Re: MR004
  • How did you get this foxed in the end - having simila issues and tried everything... reset, reboots etc and nothing,,.  Cheryl314
This message was authored by: DavyAnne
Re: MR004
Thanks that worked for me , mr004 error cleared.
