Discussion topic: Sky box keeps turning off and on and now pocture
This message was authored by: Ollyb
Sky box keeps turning on and off
This message was authored by: TravisBrowne
Re: Sky box keeps turning off and on and now pocture
Hi @Ollyb,
I had a similar issue with my Sky box. Try these steps:
  1. Check the power connections: Ensure all cables are securely connected.
  2. Restart the box: Turn it off at the mains, wait a few minutes, then turn it back on.
  3. Check for updates: Make sure your Sky box is running the latest software.
If the problem persists, you might need to contact Sky support for further assistance.
Best Regards,
