This discussion topic has been answered Discussion topic: Lost recordings
Message posted on 22 Jun 2024 05:34 PM
Hi i recently have neen having trouble with sky box saying insert sky card, but ot seems to have sorted itself for now. But all recordings on box now says unavailable is there something that can be done
Message posted on 22 Jun 2024 06:05 PM
@johnn77 wrote:
Yes several times
@johnn77 You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
failling that it appears they may have been lost
Message posted on 22 Jun 2024 05:48 PM
Re: Lost recordings
@johnn77 Have you tried rebooting your main Q box ie
Message posted on 22 Jun 2024 05:49 PM
Re: Lost recordings
Yes several times
@johnn77 wrote:
Yes several times
Message posted on 22 Jun 2024 06:18 PM
Re: Lost recordings
Thanks that's worked 👍
