Discussion topic: Lost channels
This message was authored by: Rigchick1
Lost channels
I've been gradually losing access to some channels in the past week. First it was 101 BBC1 HD, now 105 Channel 5HD and some others. I've tried resetting the box and have checked everything on the help page. Nothing has changed re dish clearance or set up and account is still the same as ever. Any ideas what's going on?
Re: Lost channels
What message are you seeing @Rigchick1 ??
Avatar for Rigchick1
Re: Lost channels
This channel is currently affected by a problem with your satellite signal.
I've tried everything suggested but nothing works
Re: Lost channels
Hi @Rigchick1
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
Re: Lost channels
Thanks for trying but as it's only a small number of channels lost and a private dish, none of that really helps. Think I'll be on hold on Monday trying to find a solution
Re: Lost channels
Hi @Rigchick1
If it is your own Dish then misalignment can affect just one or two channels.
You need a Sky Engineer to check.
Re: Lost channels
@Rigchick1
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
