Discussion topic: Error code mr104
Message posted on 03 Aug 2024 09:19 PM
Error code mr104
The multiroom sky mini box will not connect. We get error code MR104. I have tried following on screen instructions but I get the same error. I have also reset the internet. Our main box is working fine. Help !
Message posted on 03 Aug 2024 09:22 PM
Re: Error code mr104
Hi @Jo+2520
Reboot the mini as above.
