Discussion topic: Losing listing every week have to keep turning sky off to reset
Message posted on 27 Oct 2023 04:24 PM
I am loosing listing every week have to keep turning sky off to reset
Message posted on 27 Oct 2023 05:12 PM - last edited: 27 Oct 2023 05:12 PM
Re: Losing listing every week have to keep turning sky off to reset
Hi @Bass90
I assume that you are putting your Q box into Standby when not in use and you are not leaving it on with green led all the time?
Message posted on 27 Oct 2023 05:45 PM
Every week I loose listing got to keep sky box and reset.it why is tis
