Discussion topic: Losing listing every week have to keep turning sky off to reset
This message was authored by: Bass90
I am loosing  listing  every week have to keep  turning sky off to reset
Re: Losing listing every week have to keep turning sky off to reset
Hi @Bass90
I assume that you are putting your Q box into Standby when not in use and you are not leaving it on with green led all the time?
Avatar for Bass90
Every  week I loose listing got to keep sky box and reset.it why is tis
