Discussion topic: Losing connectivity despite Ethernet connection and no internet issues
Message posted on 01 Dec 2024 07:58 AM
Hi
our SkyQ keeps losing connectivity. It is connected by Ethernet to a Starlink router and all WiFi bands switched off. No issues with internet yet Sky keeps losing it, tried all suggestions, any other ideas anyone? Our AV instller thinks it could be a Sky Q box problem
Message posted on 01 Dec 2024 10:29 AM
Re: Losing connectivity despite Ethernet connection and no internet issues
@MikeYiannis wrote:
Hi
Hi @MikeYiannis
Completely reset the connection.
First reboot the router by removing the power lead for 30 seconds and then reconnecting.
Then carry out a Network reset on the main Q box with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router. Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
As soon as it connects go immediately into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
Message posted on 01 Dec 2024 07:37 PM - last edited: 01 Dec 2024 07:38 PM
Yeah, this has been happening to me lots over the last few days (and indeed, does happen every now and then for a period where lots of other people report similar issues).
It is not my router, switches, or any equipment on my network. Just for fun I tried the network reset that gets peddled every time someone has an issue - but I knew it wouldn't work. Bizarrely the SkyQ Main box just stops sending/responding to DHCP solicit's/Acks, so when the lease runs out on the network it does not pick up the address again and defaults to a 0.0.0.0 address. Unplugging the SkyQ box from the mains for 30 seconds, then powering it back on restores connection....until the lease expires.
Message posted on 23 Jan 2025 03:08 AM
Unable to connect my sky q mini box in bedroom.
Message posted on 23 Jan 2025 07:24 AM - last edited: 23 Jan 2025 07:27 AM
@Angel1929 wrote:Unable to connect my sky q mini box in bedroom.
I would start a new thread if you don't use starlink as this thread is mostly about that. (Although the problem with the Q's networking that Jason articulates above is likely not specific to Starlink routers. But with my bog standard ethernet router, I don't get that dhcp problem, Q's been solid for maybe 2 years)
