Discussion topic: Loosing some channels
Message posted on 19 Apr 2025 07:59 PM
I have lost signal for a few chanels
This channel is currently affected by s problem with your satellite signal for help press?
Message posted on 19 Apr 2025 08:06 PM
Re: Loosing some channels
This is crazy !!
I need to speak to someone please.
Message posted on 19 Apr 2025 08:09 PM
hi @Hande
Please see the following page that covers a few problems - if you follow the link through and still have problems then you should find a link to book an engineer if you have your own dish
If you have a communal system you may have to contact your building management to deal with the technicians responsible for the system
Message posted on 19 Apr 2025 08:10 PM - last edited: 19 Apr 2025 08:11 PM
@Hande wrote:This is crazy !!
This is a customer helps customer forum. (Not a realtime chat to Sky)
If you want to speak to Sky then call them...
But for satellite reception issues follow this: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
Chances are you'll need an engineer to visit to check LNB/Alignment if you have your own dish.
Message posted on 19 Apr 2025 08:12 PM
@Hande
It’s also worth noting that:
Message posted on 20 Apr 2025 09:04 AM
And also things like trees do block the signal when in full leaf, i had this problem a while back lost my satellite signal to my freesat box and had to get my satellite dish moved as the tree on the main road outside my was blocking the signal , it started with me just losing a few channels then i lost all of them, i only have a freesat box as a backup to my sky glass tv as because of the flats across the road from me i can't get freeview as the flats block that signal, hope this helps you somewhat
