4
This discussion topic has been answered Discussion topic: Setting programme choice
This message was authored by: Purloin
Hi, I've just swapped to Q and all went well apart from having to choose the programme every time you turn it on. Previously, as with most things, it just resumed from your previous channel selection. Is there a setting to make it remember what you were watching? Cheers..
This message was authored by: nigea99 Answer
Re: Setting programme choice
hi @Purloin
I am afraid it is a deliberate decsion by SKY to always present the Home page on start up & there is no option to change this
This way they can showcase new content & other content they wish to highlight.
Pressing the dismiss buton should return you to the last channel that you were watching.
hi @Purloin
Avatar for Purloin
Level 2 icon
Brillant, just the job thanks. I can deal with pressing one button! Cheers.
This message was authored by: Invisiblename
Sky Q does remember the last channel you were on, it's just that it always starts with the Home page mini tv showing.  The easy solution is to wake the Sky from standby with the power button, then immediately press the back button (open box with an error pointing left)
I am just another Sky customer!
Avatar for Purloin
Level 2 icon
Yes thanks. All good cnow.
