Discussion topic: Loading issues
This message was authored by: 1234red
Loading issues
Not loading recordings did reset and now nothing is loading help would be appreciated
Re: Loading issues
Hi @1234red
What do you mean by loading recordings?
Do you mean you cannot play them?
If you cannot make new recordings it looks like you may have a hard drive issue.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Avatar for 1234red
Re: Loading issues
It just says please wait and no recordings appear.
