Discussion topic: Jurrasic Fibre
This message was authored by: Bugsy2023
Jurrasic Fibre
Hi, I have just had Jurrasic fibre installed and the connection to my new sky box is so slow. I have current speeds of over 700mpbs but the download speed on my box is so slow. Much slower that before when I had bt at under 50 mpbs.
what's going on? Anyone else had this issue?
Re: Jurrasic Fibre
@Bugsy2023  Do you have Sky Stream?  as you've posted in the stream forum.
Avatar for Bugsy2023
Re: Jurrasic Fibre
Sorry, no it's on my sky q box. Thank you I will repost there.
