Discussion topic: Itv chnls on sky Q
Message posted on 28 Dec 2024 05:36 PM
							Itv chnls on sky Q
Sky Q box in ROI. Can't seem to retune ITV channels. Have tried latest parameters in discussion but keep getting "channel not found".
Any ideas please
GD
Message posted on 28 Dec 2024 05:39 PM
							Re: Itv chnls on sky Q
@GD15 You will need to remove the existing copies from the manual channels list 1st before adding them again.
Message posted on 28 Dec 2024 07:05 PM
Hi
I've only recently switched back to Sky Q from stream and I don't have any old ITV chnls on my list but still cannot add new ones with the updated parameters?
Message posted on 28 Dec 2024 08:33 PM - last edited: 28 Dec 2024 08:35 PM
Make sure you're entering the tuning details exactly right particularly the last bit (DVB-S2 8PSK).
ITV1/UTV, ITV4, ITVBe - 11386 V 27.5 2/3 DVB-S2 8PSK
ITV2 - 11386 H 27.5 2/3 DVB-S2 8PSK
ITV3 - 11344 H 27.5 2/3 DVB-S2 8PSK
ITV+1 channels:
11344 V 27500 2/3 DVB-S2 8PSK
While sometimes a dish alignment fault can cause a problem receiving certain transponders, it seems to be too much of a coincidence that non of the frequencies carrying ITV are working for you.
Message posted on 15 Mar 2025 03:02 PM
I found the best way to add ITV channels was to firstly delete all existing ITV Channels already saved.
I then, using the most recent data, added not the main ITV Channels but go to the regional stations, UTV AND STV worked for me and the +1 option and i saved 4 ITV stations that on the 15/3/25 worked successfully.
