Discussion topic: Issues with Sky Q and internet connection
Message posted on 25 Jan 2024 12:28 PM
What is wrong with my Sky Q box and the internet? When the weather is poor, my box loses internet very easily and then I can't watch anything!
I have a very solid and reliable mesh network throughout my property and everything else connected to the wifi is fine, except the Sky Q box keeps losing connection. It doesn't make sense that I can watch any of the apps loaded onto the actual TV which is on exactly the same network as the Sky Q box?
Very unreliable and quite frustrating! Why am I paying for Sky Q when it is so unreliable?
Is this a common issue and is there anything that can fix it??
Message posted on 25 Jan 2024 12:51 PM
							Re: Issues with Sky Q and internet connection
Any luck with this, im having teh same issues?
Message posted on 25 Jan 2024 01:06 PM
Hi @AndersonP
Exactly what and how are you connecting your main Q box to?
Also do you have any mini boxes?
Message posted on 25 Jan 2024 01:22 PM
Hi,
Thanks for replying. I have a series of Deco M9s around the flat which provide a very stable network. I have a direct connection from one Deco right into the Sky Q box which I thought would be the best and most reliable connection. I also have a Q mini which is also directly connected to another Deco unit.
As I mentioned before, everything else in the property works perfectly but it's only the Q box that regularly struggles!
Message posted on 25 Jan 2024 01:51 PM
@AndersonP wrote:
Hi,
@AndersonP when you say directly do you mean they are connected by ethernet cables to the M9's
Message posted on 25 Jan 2024 02:42 PM
Yes, Ethernet cables.
However, I had exactly the same issues when connected via wifi some time ago. I thought Ethernet cables would provide stability.
Message posted on 25 Jan 2024 08:12 PM
I have same issue, my kids like to watch youtube and it loses connection easily and they get frustrated
Message posted on 29 Jul 2024 09:44 AM
My Q box keeps losing connection too. I'm sick of having to enter the router password all the time!!
Message posted on 29 Jul 2024 09:53 AM
Yes i have this also and have a very good wifi connection around whole propety. Please keep us posted on any results.
Message posted on 29 Jul 2024 11:30 AM
I have recently changed from Sky Broadband to Trooli (UK) and have a Deco Mesh running that works perfectly for all devices except the SKY Q box. The Q keeps dropping the connection after a couple of days and I have to re-enter the wifi details.
It also means that any recordings fail when the connection has been dropped – which we don’t find out until we try and watch the recording.
