Discussion topic: Issues Pairing new Sky Q Remote Control
Message posted on 09 Aug 2023 11:04 AM
Hello,
We have a new Sky Q Remote Control and I am having problems pairing with our tv. I have followed the instructions and inputted the codes as advised, but it has been unsusscessful. I've tried four times now, resetting the remote to factor settings before each new attempt. Is there anything else I can try, or should I just call Sky for further assistance.
Many hanks,
Rachel
Message posted on 09 Aug 2023 11:18 AM
Re: Issues Pairing new Sky Q Remote Control
@RReilly2 wrote:
Hello,
Many hanks,
Rachel
Hi @RReilly2
There are no codes for Q Bluetooth remotes.
They use TV brand and model.
Try rebooting your Q box.
Then with the Q box on with green led Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 09 Aug 2023 03:39 PM
Thank you so much for your help, it's paired perfectly, thank you!!
Message posted on 31 Aug 2024 01:01 PM
Jumping on this thread. I've got a new sky remote as mine died with brand new batteries. Have held down 7 and 9 and got the 4 blinking red lights. Held down 1 and 3 for 2 bins while pointing at sky box which was on and nothing happening.
Have also tried 4 and 6 which also did 4 blinks then 1 and 3 again to same result.
Have unplugged sky Q box for 10 minutes, reconnected the presses power button to turn back on but same result.
Any ideas people? Thanks.
