Discussion topic: Sky Q box lost internet connection and will not reconnect
Message posted on 31 Aug 2024 12:13 PM
Sky Q box lost internet connection few days ago and will not reconnect.
all other devices connect to internet with no issue
Broadband provider has checked their service and equipment and report no issue.
cannot use Sky Q features that I am paying for.
I've tried all the help I could find on sky website and no improvement.
Message posted on 31 Aug 2024 12:26 PM
Re: Sky Q box lost internet connection and will not reconnect
@SteveT66 Your post has been moved from the broadband forum as that is instended for Sky broadband related issues, as you've posted your broadband provider isn't Sky the Sky Q forum would be the best place your your query.
Message posted on 31 Aug 2024 12:32 PM
Hi @SteveT66
