Discussion topic: Issue with sky mini box
Message posted on 10 Dec 2024 09:39 PM
The remote is working, I have turned off the main switch, reset the mini box. The set up appears until it gets to the part when it explains to push the home button when the screen is blank, but the mini box light stays red and still won't come on.
it is quite warm when I touch it. This hasn't worked now for about 4 days everytime I have tried it.
please advise as it looks like the little box may have packed up?
Message posted on 10 Dec 2024 10:10 PM - last edited: 10 Dec 2024 10:12 PM
Re: Issue with sky mini box
Hi @Amyclout
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
