Discussion topic: Is my new property sky q compatible
Message posted on 01 Aug 2025 06:13 PM
Moving home and the sky colleague asked whether my new property is sky q compatible. I don't know as I've not moved in yet. Does anybody know what the comparability requirements are?
And if Sky are unable to continue providing me with Sky Q when I move in, am I within my rights to cancel without penalty?
Message posted on 01 Aug 2025 06:14 PM
Re: Is my new property sky q compatible
Above should say compatibility
Message posted on 01 Aug 2025 06:32 PM
How are you supposed to know this?
I guess if it's a house with a vaguely south facing wall not obstructed by trees or other buildings at a relatively shallow angle (depends on latitude, varies between 21 and 27° in the UK) then it should be.
Message posted on 01 Aug 2025 06:34 PM
Thanks for your reply
That's exactly what I said to them, how do I know. They said I should ask the current owner but the same applies, how would they know! They don't have sky.
I guess I'll just have to wait and see when I move in.
Message posted on 01 Aug 2025 06:37 PM
Yep. As for your cancellation question, maybe a switch to Stream would work but I suspect you could reasonanly plead your case for cancellation without penalty.
Message posted on 01 Aug 2025 06:38 PM
I've not heard good things about stream so hopefully I can keep sky q. The property is a semi with a south facing wall so hopefully will be fine!
@Ben0416 I suspect it's a tactic to get you to sign up to Sky Stream rather than Sky Q, as noted by @Chodley if you have a wall that is relatively south facing and with no large trees/buildings likely to block the signal you shpuld be good to go.
Have a look on google maps by searching the postcode of your new home, you should be able to see any other neighbouring properties that have a satellite dish installed, this should give you some indication if it's possible to have a dish yourself.
Message posted on 01 Aug 2025 06:39 PM
I think it's improving but yeah, I'm not keen to make the switch.
Message posted on 01 Aug 2025 06:41 PM
Thanks for that suggestion.
I just looked on street view and there are other houses with dishes on the wall facing south, fingers crossed I'll be ok to keep it!
Message posted on 01 Aug 2025 07:01 PM
Message posted on 01 Aug 2025 07:45 PM
Just another thought @Ben0416 , if its a houing association property some can be funny about putting up dishes but if you can see on Google SV neighbouring houses with dishes i wouldn't imagine it being an issue .
Sky Q 1TB UHD
LG TV
Sky Mobile
Message posted on 01 Aug 2025 07:56 PM
Hi
I have tried to do a home move however they can't switch my broadband so I've had to cancel that. As a result, they're saying they can't switch my TV via home move until I've actually moved in, because they can't submit a home move for the tv whilst a cancellation for the broadband is pending. It's all a bit of a farce!
