Discussion topic: Internet won't connect to Qbox.
This message was authored by: Emma20
Have restarted etc. and nothing seems to work. Think the connection keeps dropping out.
Re: Internet won't connect to Qbox.
Hi @Emma20
Have you carried out a Network reset on your Q box?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
This message was authored by: gcallender
Having same issue today. Just cannot get my main Q box to connect to internet (Sky internet btw). Is there a known central problem? A whole night with only live tv available on main box. All mini boxes just a lovely blue screen!!
Have you tried the steps in the reply above?
