Discussion topic: Internet/router all connected. Sky menu appears. No programmes will load, same with Apps
This message was authored by: WendySheriff
Satellite signal and Internet showing as connected. Sky menus appear but when anything is selected just a blank black screen. Same when selecting from an App.
Re: Internet/router all connected. Sky menu appears. No programmes will load, same with Apps
Hi @WendySheriff
