Discussion topic: Internet not connecting
Message posted on 03 Mar 2023 07:40 PM
My internet is working with everything else but not connecting to my sky q box
Message posted on 03 Mar 2023 07:41 PM
							Re: Internet not connecting
I'd suggest fully rebooting both the router and the Sky Q main box.
Unplug both of them, same time, from the wall for at least 30 seconds.
Plug back in the router only, get it up and running, and run a speed test on your mobile. Now plug back in the Sky Q box, go to settings, and reset the network settings section. Then scan for your router, add in your password, and hopefully, you're back up and running.
Good luck.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
Message posted on 03 Mar 2023 07:44 PM
I have done that once but will try again and see.
thank you
Message posted on 03 Mar 2023 07:47 PM
We are with sky, so it'sBT
Message posted on 03 Mar 2023 07:53 PM - last edited: 03 Mar 2023 07:54 PM
Message posted on 03 Mar 2023 07:57 PM
Sky broadband we are with
Message posted on 03 Mar 2023 08:00 PM
OK @Mick1985
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
As you are on Sky broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.   You have two minutes after the Network reset to press the Sky router WPS button.
