Discussion topic: Internet connectivity
This message was authored by: Geor1
Still can't access internet with my QBOX. I've tried all the suggested fixes, rebooting everything multiple times. Internet fine on all other devices. Can watch live tv but no catch up or apps. Help!
This message was authored by: Emanuil
Re: Internet connectivity
If the "Network Connection" is a Cross in settings then you wont have access to the apps or catch up
Go down to "Settings", followed by "Network Connection"
Press on "Network Setup" - You will be then taken to a screen telling you to either "Reset" or select from 3 different options
If it asks you to reset, proceed with the steps on the TV
You will be then asked to connect to a Sky router, or broadband from another provider
If you have Sky Broadband select the 1st option - You will be asked to press on the WPS button on your router for ONLY 3 SECONDS, which is located on the right hand side of the router (Not the back, not the front as well) The WPS should then start flashing
If its a 3rd Party router you will connect with the password
If done correctly, the Screen will change from "Searching" to "Connecting"
@Geor1 who is your broadband provider ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
