Discussion topic: Internet connection
Message posted on 10 Dec 2024 09:10 PM
Internet connection
No Internet connection to main box although all live TV works on there except downloads.
My mini box isn't working at all though.
The broadband appears to be working perfectly though
thanks Louise
Message posted on 10 Dec 2024 09:27 PM
Re: Internet connection
thanks Louise
Message posted on 11 Dec 2024 07:37 AM
Live TV doesn't use broadband
