Discussion topic: main box is overheating and cutting out
This message was authored by: Colinp2
Re: main box is overheating and cutting out
Hi @Colinp2   Where is the box located, and how much room is left for ventilation all around?
@Colinp2
You should be able to rest the palm of your hand down on the top of the box.
(Your duplicate thread has been removed as you have this one).
Avatar for Colinp2
No.did not help
@Colinp2
You haven't answered the question as to where the box is located. If it's getting very hot you should switch it off at the plug and contact Sky.
@Colinp2 wrote:
No.did not help
What didn't help? No one has suggested anything.
If you're referring to "resting your hand on the top of the box", that wasn't intended as a solution, that was an implied "if you can't do that, then yes it's definitely overheating"
