Discussion topic: Internet connection failing on start up
Message posted on 20 Jul 2024 12:36 PM
Why doesn't my skyw box remember my internet connection and password.
I frequently switch on and no internet connection and have to go through the process to select provider (virgin) and enter password.
try his becomes very annoying when the connection can not be made. This does NOT happen with television or any other internet use in the house - just SKYQ
i have frequently done all the switch off router reboot etc but doesn't seem to work
Message posted on 20 Jul 2024 12:44 PM
Re: Internet connection failing on start up
try his becomes very annoying when the connection can not be made. This does NOT happen with television or any other internet use in the house - just SKYQi have frequently done all the switch off router reboot etc but doesn't seem to work
Hi @Robert104
Assume you are entering SSID and password for the 2.4Ghz band in a Network reset on your Q box?
Message posted on 20 Jul 2024 01:16 PM
Don't know what you mean about 2.4 etc as was not prompted for any thing like that.
my virgin router has both these set up and working for every thing else
