Discussion topic: Internet and sky tv
Message posted on 20 Aug 2024 04:29 PM
Internet and sky tv
I have had a new internet put in and it says I am on connected on my sky box but into settings I am. I am unable to see the Home Screen and other parts of sky
Message posted on 20 Aug 2024 04:36 PM
Re: Internet and sky tv
Hi @Laura224
