Discussion topic: Intermittent sound issues on all channels
This message was authored by: Jamesie01
Intermittent sound drop out on all channels
Re: Intermittent sound issues on all channels
Start with a full power down of the box for 5 - 10 minutes by unplugging at the mains, to see if that cures it.
If not, change the HDMI cable if possible then go from there.
This message was authored by: MrTee007
Hi mate had same issue with my 2TB sky Q box thought it was my TV on its way out but I was later informed that because I had used almost all the storage available or mainly stayed over 90% -that was  the cause of malfunction to keep it functioning properly I was told not to use over 80% hope that helps
