Discussion topic: Interference on Sky Q HDR Box
This message was authored by: GregT2
Hi,
Have had a V2 HDR box for a few months now. However, it has a problem I can't seem to solve.
HDR feeds like F1 and Main Event seem fine, but a 1080 feed will produce intermittent, random noise on the picture? It looks like a loss of colours, and manifests itself usually as a grid type image across part or all of the screen?
The Q box is set to 2160/10 bit.
I have replaced the HDMI between the box and it's made no difference.
If you use the tv built in tuner, the picture quality seems fine, can watch broadcasts with none of the issues I see via the Sky box?
Has anyone seen this before? Any suggestions welcome!
Thank you!
This message was authored by: Mr+Flibbles+86
Re: Interference on Sky Q HDR Box
Different frequencies/channels working better than others, dish issue possibly.
This message was authored by: Addie15
Update-We are closing this session now due to no further response within 48 hours. If you still need help, please let us know so we can re-escalate this for you. Thanks.
Avatar for GregT2
Level 2 icon
Hello there, further to previous correspondence, this issue remains outstanding. I have done the following:
- soft reset on Sky Q box
- swapped HDMI cable from amp to television
- swapped HDMI cable from Sky Q to amp
- swapped Sky Q box to be directly connected to television
The issue remains. I have also tried watching programmes using the TVs built in tuner as opposed to the Sky Q box with no issue at all.
Hi there, GregT2. I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Update-We are closing this session now but if there is anything else we can help you with, please do not hesitate to reach out. Thanks.
