Discussion topic: Incorrect region
This message was authored by: Bitsy_17
Incorrect region
My BBC and ITV are tuned to Wales and I live in Northwest England. I've left a message via the telephone but nothing has been repaired. This has been over six weeks now
Re: Incorrect region
Hi @Bitsy_17   Sorry, you are going to have to chase Sky. We cannot help you here.
@Bitsy_17
Regional programmes are based on your postcode. Have you recently moved and if so did you arrange a Sky Home Move?
@Bitsy_17  Regions are based on postcode and depending where within a region you are your postcode may actually be assigedn to the neighbouring region.
Avatar for Bitsy_17
I have had the correct region for 25 years but suddenly changed on contact renewal. Thanks everyone for your help.
Just out of interest has Channel 4 been replaced by S4C on 104, or is it just BBC/ITV that are affected?
Avatar for Bitsy_17
Yes channel 4 replaced
@Bitsy_17
Not sure what you mean by you've left a message, but you'll need to contact Sky again and speak to an agent.
These are the current methods for contacting Sky. Some methods will be more appropriate than others depending on the reason for contact……
🟧 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟧online help via this link
https://www.sky.com/help
🟧Sky Assistant 💬 should also be available via
🟧Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🟩Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
