Discussion topic: ITV signal issue
This message was authored by: Duncan50
ITV signal issue
The problem hasn't been resolved or it has started again. I have been having sound and vision Problems on ITV1 for the last few day. I have SkyQ and only ITV1 is affected. I have intermittent picture pixelation with sound break up. Occasionally the only way to get the sound back is to change channels then change back again. Some recordings are incomplete due to 'loss of signal'.
Moderator note: Amended title to better reflect query.
This message was authored by: Kevc1974
Re: Itv picture issue
The original issue was with sky stream, not sky q. So could be bad weather or other issues with sky q. ITV on my sky stream is working fine now
Avatar for Duncan50
The weather has been windy but not bad. Even today, it's calm and sunny and the picture on ITV1 is breaking up.
This message was authored by: Hunter2660
It sounds as if your dish is slightly out of alignment. I've never had Q but I assume there's a signal strength meter buried in the menu somewhere. I'd check that first of all.
Unfortunately the SKY Q signal strength info does not give information on the current channel but for a fixed test transponder set in an Enginer's menu
This message was authored by: Fizza
Re: ITV signal issue
Still having problems with itv 3 hd on my sky q box picture is very jumpy
Samsung 8k uhd tv no other channel and seems fine when watching terrestrial station itv hd
This message was authored by: Johnboy7205
I have the same issue with the same setup
This message was authored by: Stantheman418
I have been experiencing an issue with ITV HD only since the EURO football game-Georgia vs Portugal on Tuesday evening. There are lines across the screen with crackling sound and it happens intermittently. There are a few other reports of this issue online but it doesn't seem to be widespread. This issue doesn't appear to be replicated on the freeview broadcast on ITV HD.
This message was authored by: scott1212121212
also only just started having sound issue only on ITV1 it crakcle like a high pith as if there is interferance. all other channels are fine, it somes time break picture on ITV but mainly sound
any ideas
This message was authored by: Waiting+for+Atmos
I have exactly the same issue which started the same time as yours during the Portugal match.
Avid watcher
This message was authored by: Trebor4
It's happened again tonight on the england match, just in time to miss the second goal... Every ITV live football game on Sky Q I get one episode of picture/sound loss. This time it was at a bad moment. And no, it's not the weather - that's fine.
Dish is probably a bit out of alignment then
Unless everyone watching that region ITV broadcast had the same issue.
This message was authored by: DA56
Why could we not get to view London Tonight today 07/04/2026 at 18:30.
This message was authored by: DaveDrizen
What did you get?
There was a technical problem which affected the local news in many ITV regions this evening.
