Discussion topic: I need my Sky dish dish moved
Message posted on 02 Jun 2023 08:21 PM
I need my Sky dish moved due to neighbur having extension built and blocking my signal .
Message posted on 02 Jun 2023 08:30 PM
Re: I need my Sky dish dish moved
@Tania+I I'm not sure why you've posted this in the Glass/Stream firum. I've moved your post to the Sky Q forum.
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
Message posted on 02 Jun 2023 08:33 PM - last edited: 02 Jun 2023 08:36 PM
Give Sky a call @Tania+I There will be a charge of about £65.
edit: just to add, that will be dependent on there being a suitable position for it to be moved to.
Message posted on 02 Jun 2023 09:44 PM
@Daniel0210 wrote:Give Sky a call @Tania+I There will be a charge of about £65.
@Tania+I Or you could use a local independent aerial / dish installer which would probably be quicker
Message posted on 04 Jan 2024 01:03 PM
We are having an extension built at our house and have lost the signal as there is a new wall blocking the signal from the dish
Message posted on 04 Jan 2024 01:04 PM
The above reply (post 3) applies to you too.
Message posted on 04 Jan 2024 02:42 PM
@JeremyB or post 4 above
Message posted on 04 Jan 2024 03:21 PM
@JeremyB if you use an independant installer they need to put the dish at a height Sky can access it in case of future visits by Sky.
If the independant sites the dish too high then Sky installers can refuse to work on it due to Skys health and safety policy
So just something to bear in mind
