Discussion topic: Have a new box and not connecting
Message posted on 31 Aug 2024 02:16 PM
Had a new box delivered yesterday and it's not connecting to the router
Message posted on 31 Aug 2024 02:27 PM
Re: Have a new box and not connecting
@Nickney who is your broadband provider?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 31 Aug 2024 04:01 PM
Hi @Nickney .
