9
This discussion topic has been answered Discussion topic: I need 2 re-tune my mini box,can u help?
This message was authored by: JND1
Re: I need 2 re-tune my mini box,can u help?
@JND1 wrote:
What do I do now?
Hi @JND1
You don't have to retune Q boxes.
Do you mean you need to reconnect it to your main Q box?
If you do
Reboot the mini as above.
@JND1 wrote:
What do I do now?
Hi @JND1
If you do
@JND1
If your television is displaying a message about tuning, that will relate to Digital Terrestrial broadcast ('Freeview') through an aerial, not a Sky Q Mini box on an HDMI connection.
Typically you'd use the television remote control to dismiss the tuning message and then select the appropriate HDMI port for the Q box.
Avatar for JND1
Everytime I reconnect my mini box n switch it off when finished with it when I switch it back on again I've gotta go through the whole process again n it's over 3 weeks now and I'm fed up doing it!!
@JND1
Still not clear what you mean: Sky Q boxes don't need 'tuning'
If you are switching the Mini and/or main Q box off at the mains, they aren't designed for that.
Are you putting it in standby or
powering it off? The latter is best avoided. It doesn't use much power in standby.
if you are removing the power to it rather than putting it in to standby then the box is doing what is expected of it.
If you are putting it to standby where the amber light is showing then that is what we would typically expect to see
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Just to note I power my mini's off daily and they reconnect just fine after a few minutes.  (Of course the main box remains powered up)
Agreed it should not require a setup again from scratch.
I still think it's likely to be more reliable (and a lot quicker to get going) if it's left in standby.
Yup, they require no intervention - just takes a few minutes to re-establish.  (Mine are hard wired if that makes any difference)
