This discussion topic has been answered Discussion topic: I need 2 re-tune my mini box,can u help?
Message posted on 28 Nov 2023 09:20 PM
What do I do now?
Message posted on 28 Nov 2023 09:23 PM
@JND1 wrote:
What do I do now?
Hi @JND1
You don't have to retune Q boxes.
Do you mean you need to reconnect it to your main Q box?
If you do
Reboot the mini as above.
@JND1 wrote:
What do I do now?
Hi @JND1
If you do
Message posted on 29 Nov 2023 11:07 AM
Re: I need 2 re-tune my mini box,can u help?
If your television is displaying a message about tuning, that will relate to Digital Terrestrial broadcast ('Freeview') through an aerial, not a Sky Q Mini box on an HDMI connection.
Typically you'd use the television remote control to dismiss the tuning message and then select the appropriate HDMI port for the Q box.
Message posted on 12 Dec 2023 02:58 PM
Everytime I reconnect my mini box n switch it off when finished with it when I switch it back on again I've gotta go through the whole process again n it's over 3 weeks now and I'm fed up doing it!!
Message posted on 12 Dec 2023 03:06 PM
Still not clear what you mean: Sky Q boxes don't need 'tuning'
If you are switching the Mini and/or main Q box off at the mains, they aren't designed for that.
Message posted on 12 Dec 2023 03:17 PM
Are you putting it in standby or
powering it off? The latter is best avoided. It doesn't use much power in standby.
Message posted on 12 Dec 2023 04:10 PM
if you are removing the power to it rather than putting it in to standby then the box is doing what is expected of it.
If you are putting it to standby where the amber light is showing then that is what we would typically expect to see
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 12 Dec 2023 04:11 PM
Just to note I power my mini's off daily and they reconnect just fine after a few minutes. (Of course the main box remains powered up)
Message posted on 12 Dec 2023 04:16 PM
@PandJ2020 wrote:Just to note I power my mini's off daily and they reconnect just fine after a few minutes. (Of course the main box remains powered up)
Agreed it should not require a setup again from scratch.
I still think it's likely to be more reliable (and a lot quicker to get going) if it's left in standby.
Message posted on 12 Dec 2023 04:17 PM
Yup, they require no intervention - just takes a few minutes to re-establish. (Mine are hard wired if that makes any difference)
