This discussion topic has been answered Discussion topic: I have ordered a new sky q box, do I really need a sky engineer to come out?
Message posted on 10 Oct 2023 05:25 PM
I have ordered a new Sky Q TV box, do I really need a Sky engineer to come to the house?
Message posted on 14 Oct 2023 11:30 AM
@Kieran208891 wrote:
Finally got my sky q box
Now have a new problem. Sky Q viewing card doesn't seem to be working. Have inserted it chip up and still saying no card inserted
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Message posted on 10 Oct 2023 05:27 PM
Re: I have ordered a new sky q box, do I really need a sky engineer to come out?
If there hasn't been Q at the address before , then yes: a satellite dish needs installing or modifying.
Message posted on 10 Oct 2023 05:28 PM
It is a just a replacement box - have satellite dish and all already
Message posted on 10 Oct 2023 05:36 PM - last edited: 10 Oct 2023 05:36 PM
Did you have Q before or HD? They don't normally send an installer if it's Q -> Q
Message posted on 10 Oct 2023 05:42 PM
It is sky Q - thank you
Do I need to have the old box ready to send back with the delivery driver or can I do that in my own time?
Message posted on 10 Oct 2023 05:51 PM
You do. And make sure the viewing card isn't in it
Hi @Kieran208891 Is it simply a box swap, or an engineer visit? If it is simply a box swap then you must hand over your old box before the driver will leave the replacement (important, keep your viewing card). If the old box is not ready, the driver will leave and take your new box with him.
Message posted on 10 Oct 2023 06:27 PM
It will be a swap but What if me and my partner work all day and won't be home when the delivery driver turns up?
How is this possible?
Message posted on 10 Oct 2023 06:37 PM
Hi @Kieran208891 It sound's like you need a house sitter for the day, or perhaps give Sky a call and see how they can help.
Message posted on 10 Oct 2023 06:46 PM
@Kieran208891 wrote:It will be a swap but What if me and my partner work all day and won't be home when the delivery driver turns up?
Someone needs to be there. Bribe a neighbour with a bottle of gin.
Message posted on 10 Oct 2023 06:52 PM
Not sure if it's the same as when DPD deliver a new mobile phone, but if it is you should get an email from DPD which will have details of your 1 hour delivery time slot which would mean not having to be in all day. Perhaps someone who's completed a recent doorstep box swap can confirm…or not.
Message posted on 14 Oct 2023 11:26 AM
Message posted on 14 Oct 2023 11:36 AM
Perfect thank you - all sorted 👍🏽
