Discussion topic: No network connection
Message posted on 14 Oct 2023 10:45 AM
I have no network connection on my tv 📺
Message posted on 14 Oct 2023 10:48 AM
Re: No network connection
I do not have any network connection on my tv
Message posted on 14 Oct 2023 10:50 AM
Message posted on 14 Oct 2023 10:59 AM
Hi @Sarahmia
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
