Discussion topic: I have a constant red light on on my box but nothing is recording
This message was authored by: Ifulat
Re: I have a constant red light on on my box but nothing is recording
@Aldolad01
Select recordings
Scroll down to manage (2nd from bottom) and select it
Select deleted and you'll see the list of your deleted programs. Annoyingly you have to select each one individually and choose delete or un delete.
For me it was something stuck downloading which I found under downloading so paused it then deleted it and re-downloaded it and that solved it for me.
This message was authored by: Peter38
The red light is on all the time on my box
This message was authored by: dollie22
check your downloads and delete it has stuck when i deleted the red light went off hope this ssolves it
Select recordings
