Discussion topic: I have a constant red light on on my box but nothing is recording
This message was authored by: Aldolad01
What does it mean
This message was authored by: Chloe-W22
Re: I have a constant red light on on my box but nothing is recording
Posted by a Sky employee
Hey @Aldolad01 ! Welcome to the Sky Community forum, where customers like you are on hand 24/7 (almost) to offer some fantastic advice and help on all things Sky-related.
I seen on another post a user deleted everything from their deleted folder and that fixed their issue, can you try that?
Chloe-W22
Sky Community Manager
Have a story you want to share with us? Send your Thanks to Sky here
Avatar for Aldolad01
Level 0 icon
Red light on constantly
Hi 1st time using this, well 2nd time now cause I think I made a booboo with my 1st post lol 😆. I have a constant red light on on my sky Q box and it's been like this for a few days now and nothing is recording does anyone know what it is. Cheers Aldo
Level 0 icon
Thanks where can I find my deleted folder
@Aldolad01
Check that something you were downloading hasn't got stuck and didn't stop when it reached 100%. That happened to me the other morning. If that's happened, cancel the download and the light should go out.
This message was authored by: Togira2458
Red Record Light on Constant but not downloading or recording
Ok so recently I've been watching through a series on Sky and it downloads a few episodes for me and then the red lght comes on saying it's downloading but it's not and it's not recording... only thing that seems to work is unpugging it and restarting the download but after watching a few episodes it does it again.
Memory is barely being used to it's not that and my internet it fine to so i'm not sure what the issue is and it's not even that many episodes or that old of a program A Discovery Of Witches which i think is about 10/ 12 episodes per season and only 3 seasons, any help would be much appreciated.
Re: Red Record Light on Constant but not downloading or recording
Hi @Togira2458
Edit
If you are watching Series from On demand you can set auto download next episode in Preferences.
Then when you watch a series the next episode will start downloading automatically when you start watching the previous one.
If you still have an issue
This message was authored by: karen+wheeler
i also have a consant red recording light -----i have tried all the suggestions and its still there
ive also deleted all recordings and deleted the deleted folder .....help
I've noticed some downloads getting stuck at 100% recently causing the red light to stay lit. Check Recordings, Manage, Downloads and clear any downloads that have got stuck.
I've tried this and still having issues, don't really want to fully reset the box as not confident enough in what i'd be doing and that i can get it to work again especially with pairing my remote 😞 is there anything else i can do?
 Maybe I should just keep unplugging it and plugging it back in?
This message was authored by: Kaz4
Red light won't go iff
The red recording light wont go off
This message was authored by: Tom-W19
Re: Red light won't go iff
Hi @Kaz4
Your post has been escalated to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the chat bubble to start the conversation.
Here's more information on how Community Messaging works - https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Tom
This message was authored by: Michelle12
Red record light is always on
Red record light is always on, box is getting very hot!!
This message was authored by: Mr+Flibbles+86
We are still looking to help you. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
This message was authored by: dollie22
Thank you that worked much appreciated
