10 Jan 2024 08:09 PM
I can't get the Sky menu on my TV and the Sky Box is showing an amber light which I think should be green - I have checked all the connections and they are all connected
10 Jan 2024 08:10 PM
Hi @Jen051160
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
03 Jun 2024 10:38 PM
Not Q box mines stuck on amber it's the skyhd box help!
