Discussion topic: I can’t connect SkyQ to broadband
Message posted on 06 Apr 2024 01:21 PM
I have selected my normal network and input password several times and have also reset my Broadband (its BT) all other Wi-Fi is connected eg mobile
Message posted on 06 Apr 2024 04:18 PM
Re: I can’t connect SkyQ to broadband
Hi @S1E
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
As you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
