3
Discussion topic: How do I connect my new router to skyq
This message was authored by Tony2712 This message was authored by: Tony2712
Got new router n Ed's connect skyq box
This message was authored by oldfella This message was authored by: oldfella Answer
Re: How do I connect my new router to skyq
Hi @Tony2712
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Hi @Tony2712
Tony2712
There's no wps button on my router...
Tony2712
@oldfella @You are great! I found the WPS button...It worked...I should have known it would be hidden 🙂 Best game ever!
