5
This discussion topic has been answered Discussion topic: I am not able get bbc, bbc2 or itv
This message was authored by: LP112
Help I am not able get bbc, bbc2 or itv on my q box all other channels are fine
Re: I am not able get bbc, bbc2 or itv
@LP112
Sky will send an engineer to check and adjust the alignment of the dish.
@LP112
What are you seeing when you try to view those channels?
Avatar for LP112
A blue screen with the wording
Across the top
this channel is currently affected by a problem with your satellite signal
@LP112
Any message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Avatar for LP112
Thanks, I get all other channels so that's why I don't think it's the dish, I have tried to fix the issue through the help but hasn't worked, on phone to Sky now
@LP112
