Discussion topic: Huyy
Message posted on 27 Sep 2024 08:30 PM
Huyy
Can you record programmes from a sky q mini box?
Message posted on 27 Sep 2024 08:32 PM
Re: Huyy
Hi @JN4
Yes minis can set recordings on the main Q box.
You can have up to four minis installed on loan each subject to a one off upfront charge and all under by one single Q monthly Multiscreen subscription
However only two minis can be used simultaneously on all 2 TB boxes and the 1 TB UHD Main boxes to watch Sky Q content.
The original 1 TB non UHD box (32Cxxx) only permits the use of one mini at a time.
If Sky Apps are already being used on some of the minis these will not normally be counted as in Q use and therefore can be used in addition to the above limits.
See the following link for the Versions of main Q box referred to above.
https://www.sky.com/help/articles/sky-software-updates.
Subject to the above limits Sky Q minis can be used completely independently of the main Q box and the same or different program or recording can be viewed on each Q box. Even if viewing the same content it is completely independent and can be viewed at the same or different point.
Minis can do all the features same as the main Q box and can set or delete recordings on the main Q box hard drive. There is one single storage area on the main Q box with no profiles and no indication of which Q box has set a recording. (Unlike Sky+HD Multiroom which has independent storage and planners).
It should also be remembered that minis cannot view UHD recordings or content.
Message posted on 27 Sep 2024 08:34 PM
Re: Huyy
Set recordings? Can you record from a mini box the same way you would a sky + box?
Message posted on 27 Sep 2024 08:37 PM
Re: Huyy
Re: Huyy
@JN4 we have alrwady answered this in the threads that you have already created
https://helpforum.sky.com/t5/Sky-Q/Sky-q-mini-box-schedu/td-p/4762490
and
https://helpforum.sky.com/t5/Sky-Q/Sky-q/m-p/4762144#M667221
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 26 Jan 2025 02:56 PM
Re: Huyy
Also,I have just signed in to discovery + via sky q but when I try to watch anything I get an upgrade to watch message appear. Any ideas?
