Discussion topic: No satellite signal
Message posted on 26 Jan 2025 02:42 PM
No satellite signal
Have Wi-Fi but tv screen says no satellite signal
Message posted on 26 Jan 2025 02:54 PM
Re: No satellite signal
@Caroline122
Check the cables from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels and
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
3 - Due to the recent bad weather there’s likely to be a significant delay in getting an appointment.
Message posted on 26 Jan 2025 03:01 PM
@Caroline122 wrote:Have Wi-Fi but tv screen says no satellite signal
Sounds like your dish has been blown out alignment. You'll either need to book an engineer with Sky, and the wait for that could be many weeks, or contact a local independent and accept the cost.
