Discussion topic: How to cancel Sky HD
Message posted on 01 Jul 2023 03:01 PM
Message posted on 01 Jul 2023 03:03 PM
Re: How to cancel Sky HD
@Jacinta+N You will need to call Sky or use the following link https://www.sky.com/help/articles/cancel-sky-tv#contact-leave
On the link provided (In the UK) it should include a Message Us option between 0900-1930.
You can also call on 150 from a Sky Mobile or Sky Talk line
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
If you don't see the Contact options on the link above make sure java script is enabled on your browser.
Message posted on 01 Jul 2023 03:04 PM
@Jacinta+N
Sky TV
~ To remove part of your package you’ll need to contact Sky giving the required notice of 31 days. Be aware, the latest T’s and C’s for TV subscriptions state you can only cancel within a minimum discounted term if Sky agree to it. If they do allow it you’ll end up paying off the rest of the discounted term.
Select ‘Need more help’ at the bottom of the following link which will lead to contact details.
(Make sure the flag in the bottom right corner is the correct one ie; UK or ROI).
UK customer ~ The link may include an email link and also a Message Us option (which is normally available between 9am and 7.30pm).
ROI customer ~ it’s only by ringing or writing in.
