Discussion topic: Minibox keeps dropping connection
This message was authored by: UKRugbyplayer1968
I recently got rid of Sky broadband and upgraded to PlusNet full fibre broadband.
My main Sky Q box works perfectly fine with the new router, however when i try and connect my Sky Q minibox in the bedroom, it will work for anything between 5 seconds and 5 mins before giving the message 'Your minibox is unable to connect to Sky Q' with an error message MR204
I have tried rebooting both boxes, resetting both boxes, and each time it connects fine for a few seconds and then drops out again. With the old bog standard Sky broadband, the minibox worked ok.
Any ideas beyond the usual switching it off and on again guff?
Re: Minibox keeps dropping connection
@UKRugbyplayer1968 with a third party broadband provider you mini box does not connect to your new router it needs to connect to your main box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
