Discussion topic: How to cancel Paramount+
Message posted on 27 Jun 2024 04:04 PM
Message posted on 27 Jun 2024 04:13 PM
Re: How to cancel Paramount+
For Sky Q - Press Home on your Sky remote, then select My Sky at the bottom of the screen.
You’ll then see a screen with your purchases. Select Your products. You’ll then be asked to enter your Sky TV PIN number.
Then follow the prompts to cancel.
In the Mysky app on a phone or tablet.
Go to the TV section, then My Bill section, there will be a section listed Marketplace, under that click on View subscriptions.
You should be able to cancel it there.
Message posted on 03 Feb 2025 10:31 PM
Why on earth can't you do this via the app. Very poor customer service. Easy to add subscriptions on the app but not remove. So it makes it very difficult to manage your services for the best deal.
Message posted on 14 Mar 2025 01:57 PM
You can't do it on your phone. Typical from sky, you can spend as much as you like with the press of a button but cancelling something is virtually impossible without going through the very lengthy process of phoning them. Allowing customers to cancel as easy as it is to add products would be brilliant customer service but sky specialises in poor customer service in relation to cancelling products easily
Message posted on 14 Jun 2025 07:38 AM
nope, i can see the subscription but can't see where to cancel it
Message posted on 14 Jun 2025 07:49 AM
@Carlexis wrote:nope, i can see the subscription but can't see where to cancel it
In which of the places mentioned are you looking?
Message posted on 14 Jun 2025 08:07 AM
hiya, oops, i meant to say how, not where... from my TV I went to my sky, your products, entered my sky pin, app subscriptions, current, scrolled to ancel subscription, but when i press the confirm cancellation button it does not function.
Message posted on 14 Jun 2025 01:26 PM
Ok that's weird. Going to escalate this one.
Message posted on 14 Jun 2025 02:04 PM
Thanks for escalating. We've sent an invite to @Carlexis.
Tom
Message posted on 14 Jun 2025 09:08 PM
I'm having this same problem. I click on cancel and it does nothing? Also for paramount when trying to cancel on TV.
Message posted on 17 Jul 2025 11:25 PM
Same issue with myself unable to cancel due to no option available to do so.
Message posted on 29 Aug 2025 09:21 AM
Hi there,
I've just done this, although, like you, it's been a nightmare.
I've been using Google links, which just sent me to paramountplus.com who sent me back to sky app. Neither worked.
Basically, don't use Google links, use the proper Web.
Type in paramountplus.com/account
This will take you to your account with paramount directly, and you can cancel your free trial before payment is taken.
I have just done this and had an email from paramount confirming this.
I hope this helps 🙂🙂
